tsupanich
Jul 02, 2017Aspirant
R7000 hangs and rebooting after Sandisk Ultra Fit USB 3.0 attached
Hi All, I have a problem with my Netgear R7000 after I attached brand new SANDISK ULTRA FIT USB 3.0 FLASH DRIVE 128GB to USB 3.0 port. The rourter recognized the usb successfully, the drive shown...
- Jul 06, 2017
Hi tsupanich,
Try to update your firmware.
https://kb.netgear.com/000039940/R7000-Firmware-Version-1-0-9-6
William10a
Jul 02, 2017Master
Possible that the router's usb port can not handle the current that the attached drive needs does it have a external power supply connection port on the drive?
tsupanich
Hi William10a,
This USB device doesn't require power supply as it's just a small USB. Please see its spec from the official site: https://www.sandisk.com/home/usb-flash/ultra-fit-usb.
- William10aJul 02, 2017Master
I have seen posting about this type of issue before try the drive on the usb 2 port and see if happens again.
