tsupanich
Jul 02, 2017Aspirant
R7000 hangs and rebooting after Sandisk Ultra Fit USB 3.0 attached
Hi All, I have a problem with my Netgear R7000 after I attached brand new SANDISK ULTRA FIT USB 3.0 FLASH DRIVE 128GB to USB 3.0 port. The rourter recognized the usb successfully, the drive shown...
- Jul 06, 2017
Hi tsupanich,
Try to update your firmware.
https://kb.netgear.com/000039940/R7000-Firmware-Version-1-0-9-6
tsupanich
Jul 04, 2017Aspirant
Thank you for your suggestion. Do you think is it worth to try rollback or re-update FW? If yes, could you please suggest how I can proceed? Thank you in advance.
William10a
Jul 05, 2017Master
If you have a wired lan port on a computer and is connected too the router lan port can you do a ipconfig to see what ip address if any is on the lan port?
