Amplificator
Sep 21, 2021Aspirant
R7000 hardware revisions?
Hi. What hardware revisions exist for the R7000? I'm wondering if there are v2 and v3 etc. or if there's only the v1. The model number I'm thinking of purchasing is the R7000-100PES - does t...
Sep 21, 2021Guru - Experienced User
Only v1.
100PES is a regional marketing thing I believe.
Amplificator
Is it then safe to assume that 3rd party firmwares are still working for R7000 units bought today?
Like FreshTomato and DD-WRT specifically. I know I can just ask in their respective forums, but perhaps you or anyone else know the answer :)
- FURRYe38Sep 21, 2021Guru - Experienced User
Best places would be there 3rd party forums for sure. I presume they would be active and support help would be seen there.
- AmplificatorSep 21, 2021Aspirant
I'll await a response on this forum for a few more days and then create a thread on the other forums if needed, thanks :)
But as there's only the one revision of the R7000 I assume they work just fine. Both projects have a page where the R7000 is listed as supported with no mention of version - so I assume that's because there's only the single revision and it's still supported.
- FURRYe38Sep 22, 2021Guru - Experienced User
You'll find more experienced users on there forums as those users would be working with that FW more often than users here in the NG fourm since these forum only focus on stock NG FW.
