Smokinquack89
May 27, 2024Tutor
R7000 having issues bridge mode/repeater
Hi all i upgraded my GC and i no longer have room for wireless card in my case. I have a R7000 laying around that i was using as my main router 1-2yrs ago. I now have a T-Mobile all in one router an...
- May 27, 2024
What issues specifically are you having?
IF the R7000 worked on the last ISP router and now it doesn't on the new one, maybe something on the new router that isn't worknig well with the R7000. Something to contact the ISP about.
Can certainly try static IP configuration for the R7000.
Make sure WPA2 and AES only is set on the ISP router. Try OPEN security temporarily to see if the R7000 will connect at all.
Try changing channels on the ISP router.
May 27, 2024Guru - Experienced User
