Cartman32
Jul 14, 2022Aspirant
R7000 hook this up while at an area with no signal for phones and no cpu
I tried hooking this up in an area that i have spectrum internet but have no phone signal and no cpu. How are you supposed to do that since this should be plug and play when it's obviously not?
Jul 14, 2022Guru - Experienced User
Not sure what actual issue your having.
There's always some install process but you haven't said whats failing, whats not working, or anything to go on other than you have an R7000 and no cell service.
(fyi, a router isn't going to provide you cell service)
- Cartman32Jul 15, 2022Aspirant
The problem I am having is i can't set it up because my phone says no internet connection. And since i don't get cel signal i can't use the app because of no signal. Though my phone finds the router but no internet connection so can't use app or anything.
- plemansJul 15, 2022Guru - Experienced User
You can set it up using a web browser either on your phone or on a pc.
You don't need to set it up using the app
- Cartman32Jul 22, 2022Aspirant
Cant pull up web browser with no signal, wifi or otherwise, on phone,smart tv, or cpu. can't bring up google.com and Can't go to google play store because "No Signal"
