chowell4
Jan 30, 2024Aspirant
R7000 in AP Mode
Hi,
I've gotten a new Netgear router (XR500) and decided to put my old one (R7000) into AP Mode. I've found I haven't been able to interface with the R7000 while it's in AP mode and I've tried ...
- Feb 06, 2024
Hi all,
I had taken the R7000 in AP Mode, pressed the reset button and redid the process of adding it back on as an access point. With this I was able to make the password something I remembered and am now able to interface with the R7000 while it's in AP Mode. Thanks all for the suggestions.
Christian
michaelkenward
Jan 30, 2024Guru - Experienced User
chowell4 wrote:
I've found I haven't been able to interface with the R7000 while it's in AP mode and I've tried logging into through its newly assigned IP address as well as 'http://www.routerlogin.net'.
routerlogin.net doesn't work in AP mode.
How did you get the newly assigned IP address?
Set it on the R7000 when you put it into AP mode or reserve it in the XR500?
Look in the list of attached devices for the XR500 and put the assigned IUP address into a browser.
chowell4
I believe when I put the R7000 into AP mode I had it so that it'd automatically receive an IP from my XR500. I've gone to device manager in the XR500's DumaOS to find the AP's IP address and enter it into my browser. In fact I'll try it again and show you what it brings up.
- chowell4Jan 30, 2024Aspirant
I honestly may have forgotten what its old password was but it disables and locks me out for 5 minutes. It'll ask for serial number but it doesn't go anywhere when I enter it and press 'continue'. Perhaps I'll have to reset it with the button on the back and put it back into AP mode with new credentials. All I'm doing is trying to get to a GUI similar to how I could've seen it when it was in router mode.
- FURRYe38Jan 30, 2024Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to routerlogin.com or 192.168.1.1 using a wired PC and web browser and walk thru the setup wizard. Be sure write down all important information for safe keeping later on.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface - chowell4Feb 06, 2024Aspirant
Hi all,
Christian
- FURRYe38Feb 06, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
