markster
Mar 02, 2021Aspirant
R7000 in bridge mode cannot access admin page
My primary router is Asus RT-AC86U and R7000 is configured in bridge mode over 5G WiFi with statuc IP address - outside of Asus DHCP IP range. On first reboot I am able to access R7000 admin page wit...
antinode
Mar 02, 2021Guru
> [...] R7000 is configured in bridge mode over 5G WiFi [...]
What, exactly, does "bridge mode" mean to you?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Set Up the Router in Bridge Mode". Is that what you did?
> [...] with statuc IP address - outside of Asus DHCP IP range. [...]
Terminology: A "static" address is configured on the device itself.
What you configure on a (DHCP server on a) router is a reserved dynamic
address, not a static address. Either one should fix the address of a
device, but some implications are different.
Did you reserve an address for the R7000-as-bridge in the DHCP server
in your main router, or actually configure a static (LAN) address on the
R7000-as-bridge?
> [...] On first reboot I am able to access R7000 admin page without
> issues. [...]
Using that reserved or static IP address?
> [...] After a while I am not able to access the admion page. [...]
"not able" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] I am on the latest R7000 firmware. [...]
As always, an actual version number would be more useful than your
opinion of what's "latest" today.
> [...] Is that a bug ?
"After a while" makes it sound that way.
markster
antinode wrote:> [...] R7000 is configured in bridge mode over 5G WiFi [...]
There is only one Bridge Mode on R7000. Have been enough years in IT (30+) infrastructure that it means what it is.
R7000 static IP 192.168.50.115 and main router DHCP range is 192.168.50.32-63
Not need for any sort of reservation since R7000 is outside of DHCP IP range.
R7000-as-bridge?
> issues. [...]
Whan trying to access R7000 admin age re: http://192.168.50.115/Start.htm with the browser it times out spinning and nothing happens.
Latest Netgear version: V1.0.11.116_10.2.100
Nothing shows in the main router log or R7000 log. It seems as the httpd service on R7000 hangs, but I have no means to actually check. Maybe there is but I just don't know how to validate that.
It is strange bit when this happens both devices attached to physical ports on R7000 do have internet access and working jsut fine, so this is not a complete disaster.
- antinodeMar 02, 2021Guru
> There is only one Bridge Mode on R7000. [...]
I may know that, and you may know that, but my assuming that anyone
around here knows that would waste too much of my time, because many
visitors here don't know it.> Not need for any sort of reservation since R7000 is outside of DHCP IP
> [address] range.On many routers, address reservation works with ex-pool IP addresses.
All the reservations on my D7000 are outside its (small) DHCP pool.> [...] It seems as the httpd service on R7000 hangs, but I have no
> validate that.With sufficiently old firmware, you could enable Telnet access,
Telnet into the thing, and use something like "ps" to find out, but they
broke that capability a while ago:
https://community.netgear.com/t5/x/x/m-p/1786837Actually, if its httpd were all dead (not mostly dead), then I'd
expect a quick "connection refused", not a slow hang. Might be some
more subtle problem.> Latest Netgear version: V1.0.11.116_10.2.100
You might try something older. V1.0.9.42_10.2.44 was popular.
