jfg2
Sep 08, 2023Aspirant
R7000 in Bridge mode
Hello I am trying to setup my Nighthawk R7000 ac1900 in bridge mode, but I am running into some issues. Here is my setup: Arris TG4482A Gateway -wifi-> R7000 Router(bridge) -ethernet-> Computer ...
jfg2
I forgot to add that it seems to mess with the Gateway, wifi stops working, cable tv stops working , my Lan setup kept working though.
The gateway needs a reboot once it seems in that state.
Sep 10, 2023Guru - Experienced User
Whats the distance in between the ISP router and the R7000?
What channels are you using on the ISP router?
5Ghz?
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser.
