jfg2
Sep 08, 2023Aspirant
R7000 in Bridge mode
Hello I am trying to setup my Nighthawk R7000 ac1900 in bridge mode, but I am running into some issues. Here is my setup: Arris TG4482A Gateway -wifi-> R7000 Router(bridge) -ethernet-> Computer ...
Sep 14, 2023Guru - Experienced User
jfg2 wrote:
Thank you for trying all those tests!
I wanted to change my channel, but it looks like its not an option on my gateway anymore…(thanks to a sneaky firmware update on their end..)
Can you ask the ISP to change the channels? Try 40 or 48 or 149 on the ISP modem
I downgraded the firmware to v126 to see if it helped, no luck.
Did you factory reset and setup from scratch after you installed the FW?
Is there any settings I would need to do on my gateway part maybe?
Be sure any Smart Connect is disabled.
Also, when re-doing a “fresh” install, comparing to your “status”, it said that the DHCP Client was still On, i thought it would automatically go off once its in bridge mode no?
I am pretty much a beginner in those kind of things, thank you for your help!>
If the FW isn't stable, the router is of age now and not sure if NG will do anything to fix it.
Sep 18, 2023Guru - Experienced User
Just to let you know I've left my R7000 up over the weekend. Been almost 4 days, still up and running good in brige mode. FW v.126 seems to be the most stable. Not sure what's wrong with v.13x versions.
