FN's avatar
FN
R7000 intermittent connection drops
The R7000 keeps dropping connections. randomly. I think it may be related to it not picking correctly the att uverse info when configured in AP mode. I had to manually enter the AP config info. but it seems like its still hacing some issues like dropping connections, sysmts connecting to wifi when booted up but not connecting to the internet as fast, no connectivity on mobile devices or delayed connectivity
thoughts on the issue.
thank you
  • FN's avatar
    FN
    Apr 05, 2016
     I think we can close the issue with connection dropping. I've resolved the issue back to a conflict in DHCP. which is weird. I do have another thread for wifi connection over 5g being about 20Mbps slower than what it should be.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi FN,
    What is the firmware version of your router?
    • FN's avatar
      FN
