Theverge
May 26, 2016Aspirant
R7000 internet problem with newest F/W
I have the wifi speed problem from last week with only 50 download and 95 upload, which i sopose to have 150 up/download, so i tired to reset the the router and update to the newest firmware V1.0.5.6...
- May 29, 2016
Hello guys , finally i fix the problem, i dont have the setting with "set on demon", since i use DHCP servers form my IPS, the way i fix the problem is leaving nothing with factory setting, i am manually changing every setting on the router, open the DDNS, VPN, downloading manager, and BOOM, problem solved, at least it will not disconnect from the Internet, but still in the log it shows reconnect to Internet every 45-50 mins, but i don't have the feeling about disconnect from the Internet. Actually the factory setting brings the problem.
Theverge
May 27, 2016Aspirant
now i find more problem, in the log it says Internet disconnect and connect after 1 mins, it happens every 45 mins, but the ip renew time is 2 hours, sometimes the router can't assign ip address to some devices, everything is default.
