Log4J2
Jun 17, 2022Tutor
R7000 Internet Speed not the same as Modem
Hi all, Read through a few threads here about a similar issue, some are a little out-dated regarding the "preferred firmware" people have tested and gotten the best results with. ISP: Spectr...
- Jun 17, 2022
Factory reset the router.
during the reinstall, make sure to leave qos, access control, traffic monitoring, and parental controls disabled.
that router is 9 years old and needed cut through forwarding (ctf) to hit gigabit speeds. those services disable it.
so try that and then test the speeds.
Jun 17, 2022Guru - Experienced User
How are you speed testing? Wired or wireless speed testing?
What I see with mine:
- Log4J2Jun 17, 2022Tutor
Router firmware version: 1.0.11.134_10.2.119
ISP Modem: Looks to be Spectrum branded - EU2251 DOCSIS 3.1 eMTA
