Log4J2's avatar
Log4J2
Tutor
Jun 17, 2022
R7000 Internet Speed not the same as Modem
Hi all,    Read through a few threads here about a similar issue, some are a little out-dated regarding the "preferred firmware" people have tested and gotten the best results with.   ISP: Spectr...
  • plemans's avatar
    Jun 17, 2022
    Factory reset the router.
    during the reinstall, make sure to leave qos, access control, traffic monitoring, and parental controls disabled.
    that router is 9 years old and needed cut through forwarding (ctf) to hit gigabit speeds. those services disable it.
    so try that and then test the speeds.
