Log4J2
Jun 17, 2022Tutor
R7000 Internet Speed not the same as Modem
Hi all, Read through a few threads here about a similar issue, some are a little out-dated regarding the "preferred firmware" people have tested and gotten the best results with. ISP: Spectr...
- Jun 17, 2022
Factory reset the router.
during the reinstall, make sure to leave qos, access control, traffic monitoring, and parental controls disabled.
that router is 9 years old and needed cut through forwarding (ctf) to hit gigabit speeds. those services disable it.
so try that and then test the speeds.
Log4J2
Jun 17, 2022Tutor
Should the factory reset be done through the UI portal or the paperclip button on the back?
Which is preferred? Assuming both accomplish the same task, but I never know with NetGear sometimes.
Jun 17, 2022Guru - Experienced User
Either should work. Its just to force the router to reset the CTF. Sometimes even disabling those services doesn't re-enable it and thats where the reset comes in.
