BobOhio
Feb 27, 2021Aspirant
R7000 is 2.4 GHz but AC1900 Extender is 5GHz - I need to change extender to 2.4GHZ
My cameras cannot connect to 5GHz so I need to change my AC1900 extender to 2.4 GHz to match my R7000 but cannot figure out how to do it. Any help is appeciated...thanks...bob
BobOhio
Feb 28, 2021Aspirant
Thank you for responding...
My Router model is R7000 my extender is EX7000-100NAS. When I log into my routers I see the R7000 as 2.4GHz and the EX7000-100NAS as 5GHz.
I have Arlo 3 cameras.
When I plug the Arlo hub into the R7000 the cameras connect and are viewable via the internet. When I plug the Arlo hub into the EX7000-100NAS the hub blinks amber and does not connect. Arlo support tried several things but says my cameras do not work with 5GHz - not sure I can change that. I am using the extender to reach the cameras when they are placed at the back of the house.
FYI, apparently my wife's laptop can't connect to the extender either. It is a 4 year old machine running Windows 10 but the extender network name does not show as a possible network. My laptop connects just finr and I can see both networks.
Before my initial post I reviewed the manual but could not find help.
michaelkenward
Feb 28, 2021Guru - Experienced User
That suggests that the Arlo hub (which one?) does not connect through the EX7000 to the Internet. That is why the cameras don't work.
Is the EX7000 in AP mode (wired to the R7800) or extender (wifi) mode?
The cameras connect to the Arlo hub at 2.4 GHz, the link between the hub and the router is irrelevant.
If the EX7000 broadcasts at both 2,4 GHz and 5 GHz, the cameras can connect.
In my case, the Arlo hub (VMB4540) is connected over Powerline Ethernet to the R7800. The cameras happily connect to the hub.
That sounds like ill-informed drivel. It does not matter.
You might get better help in the Arlo Community.
Arlo Smart Home Security - Arlo Community
Sounds like you have a setup problem with the EX7000. Try fixing that before you worry about the Arlo stuff.
