slash1981's avatar
Aug 30, 2017
R7000 issue with WAN speeds
Disclaimer: both of my R7000s are more than 2yo so they are not under warranty.   Preambule: I had Comcast 100/20. Switched to WoW 500/50. I have two R7000. RouterA acts as a router (DHCP/ACL and s...
  • TheEther's avatar
    TheEther
    Aug 30, 2017
    This is a known issue. AP mode disables hardware acceleration between the WAN and LAN ports. The workaround is to connect the R7000 to the network via one of its LAN ports. IOW, leave the WAN port disconnected. Note: You will lose the ability to log into the router's setup pages. Move the cable back to the WAN port for maintenance. Alternatively, disable AP mode and disable the DHCP server. Assign a sensible, unused IP address in the subnet. Then connect via the LAN port.
