Pacey_IV
Dec 30, 2021Aspirant
R7000 Issues after factory reset - IPv6 - Speedtest/QoS - Remote management port - DynDns
Hi, I have the Netgear R7000 Router WiFi Nighthawk, Dual Band AC1900. I've upgraded the firmware to version V1.0.11.128_10.2.112 and then I have reseted my router using the button in the admin page ...
Pacey_IV
Jan 09, 2022Aspirant
With the firmware update of January 6, the dns service is back to work. All the other problems remain :(
- DexterJBJan 18, 2022NETGEAR Moderator
Hi Pacey_IV, please try resetting the router back to factory settings and setting it back up from scratch instead of reloading your previous config file if that's what you're doing. Let us know how it goes.
Dexter
- Pacey_IVJan 18, 2022Aspirant
> IPv6
It's back to work after I enabled the option "respont to ping on internet port". My internet provider does some monitoring operation and doesn't give me ipv6 packet if it doesn't see me reachable. Mybe something change with the last firmware becouse I dind't needed this option before firmware upgrade.
> QoS and Speedtest
Same situation after reset.
The list of connected devices is also unreliable.
Same ip with different mac address (192.168.1.8)!
192.1681.17 (the extender) not in the router list, yet I connected to it from a computer connected by cable to the router. Other devices that are present in the connected devices from the extender and not in the router's list.
If the router can't show the correct list of devices connected to it and can't even measure the correct bandwidth, what does it do with the QoS rules?
