Pacey_IV
Dec 30, 2021Aspirant
R7000 Issues after factory reset - IPv6 - Speedtest/QoS - Remote management port - DynDns
Hi, I have the Netgear R7000 Router WiFi Nighthawk, Dual Band AC1900. I've upgraded the firmware to version V1.0.11.128_10.2.112 and then I have reseted my router using the button in the admin page ...
schumaku
Jan 20, 2022Guru - Experienced User
I can no longer set the port for accessing the router remotely. I no longer find any section that allows me to do so.
Has anyone experienced the same problems? There is a solution?
In an attempt to minimize the potential access vectors (and to answer security related questions like intrusion prevention, offer https for all routers, provide certificate based auth on https only, ...) I believe Netgear is in a process of removing the port based remote access as part of their regular firmware maintenance, retaining the local and the App based cloud access only. This changes the name of the menu item there from Remote Management to Web Based Management, too.
- Pacey_IVJan 20, 2022AspirantYa. This is not a big problem. I have configured the VPN and I can access to the router config page.
