Jpenor1
Mar 21, 2020Initiate
R7000 keeps dropping wifi connection
My Nighthawk Router R700 keeps dropping signal. I've rebooted it, reset it and checked for updates. Still having problems. I've even done this with my modem. These are brand new, only 3 1/2 months o...
billscott92787
Sep 17, 2020Star
Gneisguy13 I had a Linksys after the Cisco purchase and didn't have any issues. I work with Cisco routers all day long for work. I been looking at the ASUS Rapture GT-AX11000 for WIFI5. If WIFI6 not sure what router to go with. I have never messed with MESH routers so I'm hesitant to go down that track. If I do I prefer to have something other than Amazon or Google MESH though. Any other recommended MESH routers? I've read up some on MESH routers. What's the benefit of using a MESH setup versus just having a single router? I assume multiple APs across the home to load balance the traffic?
Gneisguy13
Sep 17, 2020Guide
It looks like most companies now offer MESH routers as it looks like the wave of the future especially in these times of quarantine.
I've heard Amazon and Google Nest being the most popular but most are probably sourced from the same factories in Asia that use similar components. If you forego the firmware then all you're selecting from is how the shell/packaging looks like or price differences.
Between the two, I hear less complaints from Amazon users compared to Nest users.
