Jpenor1
Mar 21, 2020Initiate
R7000 keeps dropping wifi connection
My Nighthawk Router R700 keeps dropping signal. I've rebooted it, reset it and checked for updates. Still having problems. I've even done this with my modem. These are brand new, only 3 1/2 months o...
APACHE_BEAST
Jul 12, 2021Aspirant
I bought my 7000 nighthawk 10 weeks ago and everyday I too have to reboot my router . I called twice and tech support walked me through firmware update . Today my wifi dropped again and I just finished rebooting it ,so I'll call tech support today and also will extend tech support warranty ( thinking I'll need it )
- michaelkenwardJul 17, 2021Guru - Experienced User
APACHE_BEAST wrote:
I bought my 7000 nighthawk 10 weeks ago and everyday I too have to reboot my router .Without knowing why you have to reboot, no one can offer any suggestions. That and the absence of any detail about the rest of your network
There is no point in expecting to find useful solutions in a long and growing discussion that started two years ago and may be be down to a completely different issue. There are many reasons why wifi can have issues, many of them may have nothing to do with your router.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one, so if you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.
APACHE_BEAST wrote:
....and also will extend tech support warranty ( thinking I'll need it )One set up and running as designed, these things rarely need extra support. And this place is free. If your problem is down to hardware problems, the warranty process covers that for at least a year.
