Jpenor1
Mar 21, 2020Initiate
R7000 keeps dropping wifi connection
My Nighthawk Router R700 keeps dropping signal. I've rebooted it, reset it and checked for updates. Still having problems. I've even done this with my modem. These are brand new, only 3 1/2 months o...
Gneisguy13
Sep 17, 2020Guide
That is EXACTLY the same problem I had with the defective AC1900. Thank you for bringing this up billscott92787 !
That's more than I was willing to do considering it was a brand new router fresh out of the box and I just dropped a good chunk of change for this.
The replacement AC1900 has been in place for the for past 5 days without ANY hitches.
4utommyboi
Nov 23, 2021Aspirant
Okay so this seems to have solved my problem!
Go to http://192.168.1.1/WiFi_HiddenPage.htm and switch all avalible settings to "auto"
