Zerodius
Dec 03, 2020Tutor
R7000 keeps losing internet
Hi, I have paired a Motorola MB7621 modem with the Nighthawk R7000/AC1900 Smart Wifi Router for my home network. My ISP is Xfinity and my plan provides for speeds of up to 600 mbps. I had n...
Dec 03, 2020Guru - Experienced User
It is. go to the support site (see link) and click on downloads. Then "+ previous versions"
Zerodius
Dec 03, 2020Tutor
Thank you. I guess I can try this out the next time there is a major outage and see if that improves. I would prefer not to pay to rent Xfinity equipment or buy a new router if it can at all be avoided...
