Jazzpr's avatar
Jazzpr
Apprentice
Jun 25, 2020
R7000 Keeps resetting internet connection
Hi all, my WAN-connection (router->internet) seems to be unstable, and I can't fugure out why that is. We replaced the modem, that's not it, as it seems.   Exact every 15 minutes the connection dro...
  • Jazzpr's avatar
    Aug 11, 2020
    Okay, back again. And I think I figured it out.
    My ISP has a very (very!) short DHCP leasetime, and therefor the router resets all its connections when the lease is renewed.
    Renewing the lease however, doesn't exist in 'the wild'; it just expires and is setup again, no matter the IP that's been assigned.
    That means all (wifi) connections are lost, and must be setup again. Horror. Really.
    I think Netgear has a challange here to make its hardware compatible with this - imo not very practical - way of handing DHCP leasetimes.
    In the meantime I've dumped my Nighthawk and replaced it with a TP-link router given by the ISP; all problems are gone and my connection has never been this stable. Hooray!
