vb85
Jan 19, 2021Aspirant
R7000 latest Firmware update
Hi all,just joined and am new to the forums. Have had my router a few years and have always updated the firmware after I recieived email from Netgear by going into the router settings on my d...
Portwey84
Jan 20, 2021Virtuoso
Well I've not looked at the forum for a week or so, but as this thread has revealed, v.116 has been released and so I'll be updating after this post.
Interesting to see that when logged into the browser GUI, the check update firmware still doesn't work. It states it's connecting to the Netgear server and then comes back with no new firmware available. Same on the Nighthawk App. It's ridiculous that Netgear can't even sort this out.
As with the previously released firmware versions, I've had no problems with the day to day operation of the router and so I hope it continues with this latest release. I also concur about not downgrading to 3 year old firmware versions. That to me just doesn't make any sense from a security perspective. Clearly, if the latest firmware versions aren't working for some router owners, then that indicates either a problem with the router, environmental problems, problems with ISP's or corrupted/failed firmware uploads.
vb85
Jan 21, 2021Aspirant
As far as the release date of V1.0.9.88_10.2.88 I'm not sure but the release notes say updated 12/13/20,but I'm thinking it must be older than that because the last time I updated was in November or so. I'll keep an eye on the forums for the next couple weeks and if there aren't a lot of problems posted with .116 I'll update to that. Not having any problems with 9.88 but if it's older I'd rather update to something newer for security reasons. If I do so with no problems then I'll mark this as solved.
A big Thank You to everyone who replied for your help and insight.
vb85
- Portwey84Jan 21, 2021Virtuoso
vb85 wrote:As far as the release date of V1.0.9.88_10.2.88 I'm not sure but the release notes say updated 12/13/20,but I'm thinking it must be older than that because the last time I updated was in November or so. I'll keep an eye on the forums for the next couple weeks and if there aren't a lot of problems posted with .116 I'll update to that. Not having any problems with 9.88 but if it's older I'd rather update to something newer for security reasons. If I do so with no problems then I'll mark this as solved.
vb85
All the release notes for all of the older firmwares were updated around that date for some reason, probably something to do with the guidance notes on updating firmwares. V.42 which appears to be the 'stable' favourite for all those that can't seem to get any other firmware to work properly, is now over 3 years old and I can tell you now, I wouldn't personally put that on my router!
That aside, I have since run Bitdefender Home Scan and yet again, the only equipment that shows up as being a security risk, is, yup you guessed it, the router itself.
- DoctorXJan 21, 2021Guide
I was able to set Timezone to "GMT-5:00 Eastern Time" and I was able to specify my own NTP server. No issues with this.
Perhaps the problem only occurs with "GMT" ?- Portwey84Jan 21, 2021Virtuoso
DoctorX wrote:I was able to set Timezone to "GMT-5:00 Eastern Time" and I was able to specify my own NTP server. No issues with this.
Perhaps the problem only occurs with "GMT" ?As I'm in the UK, I really do need my router to be set at GMT and to be able to set daylight saving time. With this latest release, it's not letting me do that. I prefer to select my own NTP server too and I can't even do that. I didn't have an issue prior to upgrading. That aside, I won't be downgrading to the previous version.
