bbarahi
Oct 11, 2018Aspirant
R7000 Latest Firmware V1.0.9.42_10.2.44 broke wifi
Hello Everyone,
My R7000 router just got updated to firmware version V1.0.9.42_10.2.44. When I checked the wifi speed after the update, it's fluctuating and very slow (sometimes in the range of...
- Oct 11, 2018
Always do a hard reset (paper clip thingy) after every firmware upgrade and manually enter all your settings. Your problems should be solved.
Backing up your current settings and loading them to your new firmware won't work and you will just have the same problems.
Actually, I recommend doing a hard reset every time you want to change any setting in your router. I know its tedious to reset and manually input your old settings and the new ones that you want to try out but that's the only way to maintain the performance of this router for longer periods of time.
If you finally notice any performance degredation over time, then it is again time to do a hard reset and manually enter again all of your settings even if you don't have plans to upgrade/downgrade your firmware. Always manually enter your settings through the web browser interface (not Genie app) and don't content yourself in loading just a backup. You will encounter problems with the performance of your router.
myersw
Oct 11, 2018Master
It is recommended to do a reset and reconfigure after a firmware upgrade, especially if encountering problems. Seems that existing configuration may not be compatable with the new firmware. So I would suggest you do a backup of the configuration so that you can get back easily to your current installed firmware and then once again install the new firmware and do a new configuration, do not use the configuration backup file with the new firmware.
Unfortunately this seems to be the way things are done. Not a very good way and one of the reasons I sold my r8000 and r8000p. Should not have to do a reset and new configuration after a firmware update IMHO and in my experience with other manufactures is not needed.
