bbarahi
Oct 11, 2018Aspirant
R7000 Latest Firmware V1.0.9.42_10.2.44 broke wifi
Hello Everyone,
My R7000 router just got updated to firmware version V1.0.9.42_10.2.44. When I checked the wifi speed after the update, it's fluctuating and very slow (sometimes in the range of...
- Oct 11, 2018
Always do a hard reset (paper clip thingy) after every firmware upgrade and manually enter all your settings. Your problems should be solved.
Backing up your current settings and loading them to your new firmware won't work and you will just have the same problems.
Actually, I recommend doing a hard reset every time you want to change any setting in your router. I know its tedious to reset and manually input your old settings and the new ones that you want to try out but that's the only way to maintain the performance of this router for longer periods of time.
If you finally notice any performance degredation over time, then it is again time to do a hard reset and manually enter again all of your settings even if you don't have plans to upgrade/downgrade your firmware. Always manually enter your settings through the web browser interface (not Genie app) and don't content yourself in loading just a backup. You will encounter problems with the performance of your router.
Rialbo
Oct 16, 2018Aspirant
Just Updated to V1.0.9.42 and no issues 134mbs down 12mbs up on Spectrum. Have never needed to hard reset this R7000 since purchase and 5 updates. Always backed up old rev. first.
- RialboOct 16, 2018AspirantAddendum to: My R7000 supports 37 devices, 5 pcs, 6 printers, 2 extenders, 2 cameras, Alexa, FTP Share weather station and various currently offline. Would be a nightmare to manually reboot and recreate the configs so hope never need the process .......
