bbarahi
Oct 11, 2018Aspirant
R7000 Latest Firmware V1.0.9.42_10.2.44 broke wifi
Hello Everyone,
My R7000 router just got updated to firmware version V1.0.9.42_10.2.44. When I checked the wifi speed after the update, it's fluctuating and very slow (sometimes in the range of...
- Oct 11, 2018
Always do a hard reset (paper clip thingy) after every firmware upgrade and manually enter all your settings. Your problems should be solved.
Backing up your current settings and loading them to your new firmware won't work and you will just have the same problems.
Actually, I recommend doing a hard reset every time you want to change any setting in your router. I know its tedious to reset and manually input your old settings and the new ones that you want to try out but that's the only way to maintain the performance of this router for longer periods of time.
If you finally notice any performance degredation over time, then it is again time to do a hard reset and manually enter again all of your settings even if you don't have plans to upgrade/downgrade your firmware. Always manually enter your settings through the web browser interface (not Genie app) and don't content yourself in loading just a backup. You will encounter problems with the performance of your router.
Paul-Jan
Oct 28, 2018Tutor
Since the last frimeware I have had all sorts of weird faults: could not log in to the router with a wired PC, this had to reset the router! Various Iphone and Ipad were not connected, The chromecast did not work anymore. A Wifi repeater did not work anymore. Wifi signal was weak! I have already had to reset the router 4 times. In the basic overview does not show all names of the devices, but the names in the Advanced access control menu. Laptop is connected but not working fine. at first you think it's the internet, but is not the case.... Think strongly about going back to the previous firmware version!
To get the wifi repeater, chromecast etc operational again, I had to reset the router again! :)
