wml527
Mar 31, 2025Follower
R7000 LED meaning
I currently have an R7000 Nighthawk router. I recently had my local cable company out to update they're modem and the tech mentioned that I had a poor Ethernet connection because of one of the LED's ...
Mar 31, 2025Guru - Experienced User
Id review the user manual for LED color indications and meanings. Usually means connection rate speeds between the router and your LAN device.
What is connected to those LAN ports?
