IrvSp
Oct 11, 2015Master
R7000 Log MAC address issue, can't locate?
I keep seeing this MAC address in my e-mailed log, F0:A2:25:04:27:37, and it is NOT in my list of ALLOWED devices or ATTACHED DEVICES for the router? From the logs sent: [DHCP IP: (192.168.1.6)...
- Oct 12, 2015
Changed them but I'm wondering if it could be the USB drive attached to the Router? I use it as a Media Server (DLNA). However that has a different MAC address, c4:04:15:29:8f:3d, and I've never seen that in the log? The drive 'share' doesn't have a MAC address though.
Test will be tomorrow morning I guess?
Just discovered a Kindle that was sleeping...
Also I just looked at the log, IT IS HERE somewhere?
[Admin login] from source 192.168.1.30, Monday, Oct 12,2015 12:00:06
[WLAN access rejected: incorrect security] from MAC 2C:44:FD:61:46:24, Monday, Oct 12,2015 12:00:06
[WLAN access rejected: incorrect security] from MAC 10:AE:60:57:25:06, Monday, Oct 12,2015 12:00:05
[WLAN access rejected: incorrect security] from MAC 78:AC:C0:5C:FC:B8, Monday, Oct 12,2015 12:00:05
[WLAN access rejected: incorrect security] from MAC F0:A2:25:04:27:37, Monday, Oct 12,2015 12:00:05
[WLAN access rejected: incorrect security] from MAC 2C:44:FD:61:46:24, Monday, Oct 12,2015 12:00:05
[WLAN access rejected: incorrect security] from MAC 10:AE:60:57:25:06, Monday, Oct 12,2015 12:00:04
[WLAN access rejected: incorrect security] from MAC 78:AC:C0:5C:FC:B8, Monday, Oct 12,2015 12:00:04
[WLAN access rejected: incorrect security] from MAC F0:A2:25:04:27:37, Monday, Oct 12,2015 12:00:04
[WLAN access rejected: incorrect security] from MAC 2C:44:FD:61:46:24, Monday, Oct 12,2015 12:00:04Now as I change the passphrase to allow devices to connect I should be able to determine WHO it is?
Yeah, it was the Kindle... sheesh:
Allowed it and it connected...
[DHCP IP: (192.168.1.6)] to MAC address F0:A2:25:04:27:37, Monday, Oct 12,2015 12:12:47
Who knew?
TheEther
Oct 11, 2015Guru
A private MAC address is an address where the vendor has opted to register the OUI as private. See this page for reference. You can find the entry for OUI F0:A2:25 in the IEEE OUIs page. Warning, it's a big file.
Note that a private MAC address is different from a locally administered MAC address. A locally administered MAC address has the 2nd least significant bit set in the first octet. See the details on Wikipedia.
At first, I thought that F0:A2:25:04:27:37 was a locally administered MAC address (it's not because the 2nd least significant bit is not set). I know that Apple introduced the use of locally administered MAC addresses with iOS 8 in order to enhance privacy. It's mentioned here and described in further detail here. It turns out that iOS only uses a locally administered MAC address when probing for Wi-Fi networks, not when DHCPing for an IP address. Plus, as I already stated, the address in question is not locally administered, so the mysterious device is probably not an Apple.
Did you look at the Attached Devices page? If it's not currently attached, then that may explain why it's not showing up in Access Control.
If you are unable to find the device, then I think it's time to change your Wi-Fi passwords. You should probably change the router's admin password just to be safe. And make sure the guest network is disabled.
IrvSp
Oct 11, 2015Master
We can continue this e-mail if you wish, but I did search the list you referenced:
F0-A2-25 (hex) Private F0A225 (base 16) Private
The Attached Devices of course it wouldn't be on there. However it doesn't show on ANY list (Attached, Allowed, or Blocked) on the Acess Control page either?
Interestingly I found I asked this same question awhile ago, here (old forum) and other places with no resolution:
https://forum1.netgear.com/t5/Nighthawk-WiFi-Routers/Questions-about-my-LOG-entries/td-p/509827
http://www.dslreports.com/forum/r29729174-R7000-Log-entry-questions?group=noreply
The common denominator here is the FireTV stick.
What CAN be connected to the Router...
The Blocked list has a single device, a phone from the ISP's tech from when he was last here.
The difference between those Dec. 2014 reports and today is I was on W8.1 then and there was a way to remove the spurious phone from appearing via a Service change I found.
I suspect, but can't confirm it is related to the FireTV stick. That appears to be the start of that appearing I think?
I am assuming Access Control being turned on will help identify the device as it tries to connect. It should be blocked. Why twice at almost the same time each day (old references above have the same time if you take Daylight Savings time into consideration).
