IrvSp
Oct 11, 2015Master
R7000 Log MAC address issue, can't locate?
I keep seeing this MAC address in my e-mailed log, F0:A2:25:04:27:37, and it is NOT in my list of ALLOWED devices or ATTACHED DEVICES for the router? From the logs sent: [DHCP IP: (192.168.1.6)...
- Oct 12, 2015
Changed them but I'm wondering if it could be the USB drive attached to the Router? I use it as a Media Server (DLNA). However that has a different MAC address, c4:04:15:29:8f:3d, and I've never seen that in the log? The drive 'share' doesn't have a MAC address though.
Test will be tomorrow morning I guess?
Just discovered a Kindle that was sleeping...
Also I just looked at the log, IT IS HERE somewhere?
[Admin login] from source 192.168.1.30, Monday, Oct 12,2015 12:00:06
[WLAN access rejected: incorrect security] from MAC 2C:44:FD:61:46:24, Monday, Oct 12,2015 12:00:06
[WLAN access rejected: incorrect security] from MAC 10:AE:60:57:25:06, Monday, Oct 12,2015 12:00:05
[WLAN access rejected: incorrect security] from MAC 78:AC:C0:5C:FC:B8, Monday, Oct 12,2015 12:00:05
[WLAN access rejected: incorrect security] from MAC F0:A2:25:04:27:37, Monday, Oct 12,2015 12:00:05
[WLAN access rejected: incorrect security] from MAC 2C:44:FD:61:46:24, Monday, Oct 12,2015 12:00:05
[WLAN access rejected: incorrect security] from MAC 10:AE:60:57:25:06, Monday, Oct 12,2015 12:00:04
[WLAN access rejected: incorrect security] from MAC 78:AC:C0:5C:FC:B8, Monday, Oct 12,2015 12:00:04
[WLAN access rejected: incorrect security] from MAC F0:A2:25:04:27:37, Monday, Oct 12,2015 12:00:04
[WLAN access rejected: incorrect security] from MAC 2C:44:FD:61:46:24, Monday, Oct 12,2015 12:00:04Now as I change the passphrase to allow devices to connect I should be able to determine WHO it is?
Yeah, it was the Kindle... sheesh:
Allowed it and it connected...
[DHCP IP: (192.168.1.6)] to MAC address F0:A2:25:04:27:37, Monday, Oct 12,2015 12:12:47
Who knew?
IrvSp
Oct 11, 2015Master
Should add that Guest Network is OFF and was NEVER on as well as the WPS PIN being OFF.
The iPad's do renew their leases before the odd one occurs:
[DHCP IP: (192.168.1.6)] to MAC address F0:A2:25:04:27:37, Sunday, Oct 11,2015 03:59:38 [DHCP IP: (192.168.1.6)] to MAC address F0:A2:25:04:27:37, Sunday, Oct 11,2015 03:24:39 [DHCP IP: (192.168.1.4)] to MAC address A4:67:06:57:DD:0E, Sunday, Oct 11,2015 03:13:24 [DHCP IP: (192.168.1.2)] to MAC address 1C:AB:A7:F0:61:EB, Sunday, Oct 11,2015 03:06:55
Those are the .2 and .4 addresses. However there is a time difference so I don't think we could relate the .6's to each iPad.
[DHCP IP: (192.168.1.6)] to MAC address F0:A2:25:04:27:37, Saturday, Oct 10,2015 03:59:37 [DHCP IP: (192.168.1.6)] to MAC address F0:A2:25:04:27:37, Saturday, Oct 10,2015 03:24:39 [DHCP IP: (192.168.1.4)] to MAC address A4:67:06:57:DD:0E, Saturday, Oct 10,2015 03:02:39 [DHCP IP: (192.168.1.2)] to MAC address 1C:AB:A7:F0:61:EB, Saturday, Oct 10,2015 02:52:09
Only that it does happen after each iPad gets the lease renewal.
I've decided to add F0:A2:25:04:27:37 to the BLOCKED list and see what happens rather than wait for Access Control to put something in the log. I guess it is possible that a neighbor's device found my signal stronger and tried to connect but the time makes me think that wouldn't be the case? However the neighbor's bedroom is probably closer to my router than his is (I've helped him on occassion and know where his router is. Still it would be impossible for him to connect without my password(s). He's never been here connecting either. Would a Phone's MAC address be registered to the vendor too?
As a test if the blocking doesn't show me something tomorrow morning I think I'll disconnect the FireTV. At that hour ONLY the 2 iPad's and the FireTV are powered on. We do have a SmartTV but that is off but I guess there is the possibility of it doing it even if off as AC is connected?
I really don't think it is outside my house though?
netwrks
Oct 11, 2015Master
Or give the Fire TV a static ip address and see what shows up in the logs..
- IrvSpOct 11, 2015Master
Already thought of that and did that long ago:
Interesting as I looked back on the logs I've got from 8/22/2015. It did NOT happen before 9/8/2015. The FireTV Stick was used on a few times though, twice since 9/8, and on the days it was used (the stick) that MAC Address doesn't appear in the log? In all the logs I've NOT seen that MAC Address and the FireTV's (10:AE:60:57:25:06) in the same log? Wonder if it has 2 functions using different IP and MAC addresses?
