IrvSp
Oct 11, 2015Master
R7000 Log MAC address issue, can't locate?
I keep seeing this MAC address in my e-mailed log, F0:A2:25:04:27:37, and it is NOT in my list of ALLOWED devices or ATTACHED DEVICES for the router? From the logs sent: [DHCP IP: (192.168.1.6)...
- Oct 12, 2015
Changed them but I'm wondering if it could be the USB drive attached to the Router? I use it as a Media Server (DLNA). However that has a different MAC address, c4:04:15:29:8f:3d, and I've never seen that in the log? The drive 'share' doesn't have a MAC address though.
Test will be tomorrow morning I guess?
Just discovered a Kindle that was sleeping...
Also I just looked at the log, IT IS HERE somewhere?
[Admin login] from source 192.168.1.30, Monday, Oct 12,2015 12:00:06
[WLAN access rejected: incorrect security] from MAC 2C:44:FD:61:46:24, Monday, Oct 12,2015 12:00:06
[WLAN access rejected: incorrect security] from MAC 10:AE:60:57:25:06, Monday, Oct 12,2015 12:00:05
[WLAN access rejected: incorrect security] from MAC 78:AC:C0:5C:FC:B8, Monday, Oct 12,2015 12:00:05
[WLAN access rejected: incorrect security] from MAC F0:A2:25:04:27:37, Monday, Oct 12,2015 12:00:05
[WLAN access rejected: incorrect security] from MAC 2C:44:FD:61:46:24, Monday, Oct 12,2015 12:00:05
[WLAN access rejected: incorrect security] from MAC 10:AE:60:57:25:06, Monday, Oct 12,2015 12:00:04
[WLAN access rejected: incorrect security] from MAC 78:AC:C0:5C:FC:B8, Monday, Oct 12,2015 12:00:04
[WLAN access rejected: incorrect security] from MAC F0:A2:25:04:27:37, Monday, Oct 12,2015 12:00:04
[WLAN access rejected: incorrect security] from MAC 2C:44:FD:61:46:24, Monday, Oct 12,2015 12:00:04Now as I change the passphrase to allow devices to connect I should be able to determine WHO it is?
Yeah, it was the Kindle... sheesh:
Allowed it and it connected...
[DHCP IP: (192.168.1.6)] to MAC address F0:A2:25:04:27:37, Monday, Oct 12,2015 12:12:47
Who knew?
TheEther
Oct 12, 2015Guru
Like I said, Access Control is enforced after DHCP. And DHCP occurs after the Wi-Fi paraphrase is accepted. Ergo, that rogue device either has the correct paraphrase or it's plugged in via Ethernet.
I'm glad you finally decided to change your paraphrase. That's what I originally suggested.
IrvSp
Oct 12, 2015Master
Who knew?
