ScottAlv
Apr 04, 2018Initiate
R7000 Logins won't accept password
This is driving me nuts and I can't find a solution in this forum. Using 3 different browsers (Chrome, IE, MS Edge), I get the same problem. I go to www.routerlogin.net (or .com or 192.168.1.1) and u...
- Apr 04, 2018
I found a solution. I reset to factory default (put pin into slot in back of router and held for 7 seconds). THEN the login screen finally worked correctly. In fact, it looked differently too. Whew! Got it all updated. I hope this helps someone else.
ScottAlv
spear
Apr 22, 2018Aspirant
I had the same problem and this worked, thanks!
