Spartin153
Feb 06, 2021Aspirant
R7000 looses access and password weekly
First started off about every other month I would loos internet access but I figured it was probably my ISP changing IP address, then recently I have been having to restart my router weekly for the pa...
Feb 06, 2021Guru - Experienced User
What modem/gateway is the R7000 connected to?
What firmware is on the R7000? It hasn't been known for the best firmwares.
The agreed upon stable version is the 1.0.9.42
But some have had luck with the newest 1.0.11.116
Any changes in frimware to the R7000 should be done over a hardwired connection. I also recommend a factory reset and a clean install for best results.
Spartin153
The version is currently on 1.0.9.88
I have tried to update and said it’s up to date. I will try a clean wipe and go from there
Where do I download the old version of firmware from?
- plemansFeb 06, 2021Guru - Experienced User
You can get it from here:
Nighthawk R7000 | AC1900 Smart WiFi Router | NETGEAR Support
I'd try manually updating first to the newer version. Some have had great luck with it
- Spartin153Feb 06, 2021AspirantModem is a CM700
