Spartin153
Feb 06, 2021Aspirant
R7000 looses access and password weekly
First started off about every other month I would loos internet access but I figured it was probably my ISP changing IP address, then recently I have been having to restart my router weekly for the pa...
Feb 06, 2021Guru - Experienced User
You can get it from here:
Nighthawk R7000 | AC1900 Smart WiFi Router | NETGEAR Support
I'd try manually updating first to the newer version. Some have had great luck with it
Spartin153
Modem is a CM700
