Robbli
Apr 02, 2016Aspirant
R7000 loosing usb connection to SSD and HDD sporadically
Hi When I'm sometimes copying or reading files from my SSD or HDD attached to either the usb 2.0 or 3.0 ports on the R7000, it looses connection which is very frustrating. I noticed the USB light...
- Apr 11, 2016
As far as I know SSDs do not require a third party driver as they are plug and play devices. Like I said before, the SSD requires more power than HDD surprisingly enough.
Anyway, I managed to get a refund on the SSD and instead bought a Seagate 1TB slim HDD which works fine.
Thanks for your help and time.
JamesGL
Apr 11, 2016NETGEAR Employee Retired
Hi Robbli,
For SDD, does it require to install a driver in order for it to work on a computer? If yes, it is the reason why it won't work with the router.
Robbli
Apr 11, 2016Aspirant
- JamesGLApr 13, 2016NETGEAR Employee Retired
Hi Robbli,
Thank you for your update. You may tag your post as accepted solution.
