fs_at12
Oct 01, 2022Initiate
R7000 losing the internet connection
Hi,It is ridiculous that you just have 90 days for “real” support, and after that, you have to bother other people who don't have anything to do with NetGear, just using their technology, what for th...
Oct 01, 2022Guru - Experienced User
1. what actual firmware are you on? "the latest" isn't a number and changes
2. what modem/gateway is it connected to?
3. Does the issue happen to all devices, just wireless devices? Do wired drop?
- fs_at12Oct 01, 2022Initiate
Thank You for your Reply!
1. V1.0.11.126_10.2.112
2.the modem...I dont know its provided from the company, its also labaled from the company , so Ireally dont know (Connect Box from UPC)
3. Yes the internet is gonne for all, wired and wifi connected devices
- plemansOct 01, 2022Guru - Experienced User
1.0.11.136 is actually the latest. You can download it here:
https://www.netgear.com/support/product/r7000.aspx
The R7000 has responded favorably to factory resets after firmware changes. Not saying you have to, but its a good option with the r7000.
Modem is bit of a key as some ISP's provide modem/router combo devices and it can cause a double nat.
Which is why we ask. I'd look at the label on the modem/gateway
- michaelkenwardOct 02, 2022Guru - Experienced User
As plemans says, this could be important.
It probably has a label on it, but one clue would be the number of Ethernet LAN ports on the thing. If it has more than one, it could be a modem/router. Many of these have four LAN ports. Another clue is of it also does wifi.
