Neekluc
Jul 02, 2021Initiate
R7000 Manually reinstall router
 I've been reading a lot of the suggestions for why my R7000 Nighthawk router needs almost daily rebooting. I see and agree that it must be a firmware issue as I had a tech here 6 months ago and he to...
Jul 03, 2021Guru - Experienced User
You can downgrade by downloading it from the support site. Then just follow the manual update process but use the older firmware.
Before downgrading though, did you try the latest 1.0.11.123 version? You could install that, do the factory reset, reinstall. It might work fine for you.
here's the manual firmware update process:
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
and where to get firmware:
Nighthawk R7000 | AC1900 Smart WiFi Router | NETGEAR Support
I'd be the reason netgear doesn't do anything about it is that most don't have issues. If you read the reviews (not the forums) theres tons of people that do great with it. But when they don't, they end up on here. so it makes it seem like everyone has issues.
