truthlesshero
Aug 08, 2015Guide
R7000 max speed problems (300mbps?)
Hi I've tried googling the crap out of this problem, playing wiht settings, asking reddit for help, chatting with a tech support person and nothing seems to have resolved my problem. I was h...
- Aug 09, 2015Update: apparently, the problem lies with acrylic. I downloaded a different wifi scanner and it shows 1300mbps. So i'm probably more limited by my adapter. So if anyone else had the same problem, it was a superficial problem. Hopefully I'll be satisfied with ~250mbps average rate, hehe
VE6CGX
Aug 08, 2015Master
What is signal level on Acrylic? What is the number? Did you set up antenna sticks like \ I / ?
middle one straight up, two side ones forming letter V. Router front or back should point to
WiFi device, not side. Playing with router/antenna position can improve WiFi signal.
