Mikkaat
Jul 10, 2017Aspirant
R7000 NAT Session Timeout
I have an r7000 and am using it with a Logitech Harmony Hub. I am trying to configure the harmony hub to use voice coontrol on my amazon echo. I have noticed that if i reboot my router, vlice control...
- Jul 26, 2017
Hi Mikkaat,
Set the device's IP in DMZ.
JamesGL
Jul 19, 2017NETGEAR Employee Retired
Hi Mikkaat,
There is no option on any NETGEAR home router to change the NAT session. Check UPnP and make sure it is enabled. Check if you still need to open port numbers for the Logitech Harmony Hub.
- MikkaatJul 19, 2017Aspirant
Thanks for the response.
I can confirm uPnP is enabled and the appropriate port is forwarded.
- JamesGLJul 26, 2017NETGEAR Employee Retired
Hi Mikkaat,
Set the device's IP in DMZ.- JamesGLJul 31, 2017NETGEAR Employee Retired
Hi Mikkaat,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
