MG1212
Sep 13, 2016Tutor
R7000 Need newest Firmware with Arlo support
Good Morning, I need the newest Beta with Arlo support please, V1.0.6.54_1.2.3 doesnt work good for me. When i was on holiday wifi disables it self and only reset helps. But now I can´t see my ...
- Sep 14, 2016
I do also have the earlier beta (1.0.6.40, I believe) if you want to try that.
jguerdat
Sep 13, 2016Guru
There's nothing newer. Did you factory reset the router after flashing? Perhaps there's a difference in stored settings between versions. Might be useful to reset anyways just on the off chance it would help. It's been a while since I flashed it so I can't say whether there's been an additional Arlo update that would now break it but I haven't heard of such a thing. Of course, maybe this sort of thing is why the thread announcing this beta versipon has been deleted but that's just a guess.
MG1212
Sep 14, 2016Tutor
Good Morning jguerdat,
yes I have flashed new with soft and hardreset before an after flashing. It works some weeks great, but when I was not at Home, normal wifi breaks.
Back home I only could see the Arlo network, but the Camera was offline. I reseted the Router, configuerd all new, synct the Camera (I can see it in the Network overview), but can´t see it in the Arlo Menü from the Router, also can´t connect over the Arlo App or Website the Router or both.
This is because I asked for a newer Firmware.
- jguerdatSep 14, 2016Guru
