MG1212
Sep 13, 2016Tutor
R7000 Need newest Firmware with Arlo support
Good Morning, I need the newest Beta with Arlo support please, V1.0.6.54_1.2.3 doesnt work good for me. When i was on holiday wifi disables it self and only reset helps. But now I can´t see my ...
- Sep 14, 2016
I do also have the earlier beta (1.0.6.40, I believe) if you want to try that.
MG1212
Sep 14, 2016Tutor
Good Morning jguerdat,
yes I have flashed new with soft and hardreset before an after flashing. It works some weeks great, but when I was not at Home, normal wifi breaks.
Back home I only could see the Arlo network, but the Camera was offline. I reseted the Router, configuerd all new, synct the Camera (I can see it in the Network overview), but can´t see it in the Arlo Menü from the Router, also can´t connect over the Arlo App or Website the Router or both.
This is because I asked for a newer Firmware.
jguerdat
Sep 14, 2016Guru
