fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
ankydu
Dec 31, 2015Guide
One major Bug in this and the 1.0.5 firmwares:
After applying the update I reset my router with the reset switch at the back of the router. After the router rebooted, I was no longer able to access my router via my Windows 10 computer attached via LAN cable. I tried many reboots and resets but still was unable to access. I even tried my laptop via wifi and LAN cable, I was able to ping the router but not open its login page.
Finally I could login via my android tablet.
Anyone else faced this issue ???
- anygregDec 31, 2015Apprentice
Yes , has this issue with my wndr4500 as well, but if I rebooted the router I could log in again for a while then it dropped again?
Never got got to the bottom of it.... I'm sure netgear will create some really informative red text to help clear things up and show us the way lol
- ankyduDec 31, 2015Guide
My android tablet was able to connect fine but not my windows PC or laptop. Once I set the router to Wireless AP mode my PC was also able to access it fine. Even downgrading to 1.0.4 now has the same issue.
- LeeHDec 31, 2015Prodigy
I hope everyone is holding down the reset button a long time like 30 seconds in order to accompish a successful reset.
