fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
jflorance
Jan 01, 2016Star
I updated to 1.0.6.28 yesterday and have lost access to my 2.4G network. I have both 5 and 2.4 running and a 2.4G guest network . The guest network seems to work fine. I've tested it with on Android device and 2 Windows laptops. I'll entertain any workarounds or solutions.
Probably doesn't matter but I turned off Arlo right after the update.
GyroD4
Jan 01, 2016Tutor
I just updated as well. My 5G is fine but my 2.4G status shows good, but nothing will connect to it. I went in and disabled Arlo, but that didn't help, I still can't connect to my 2.4G network. Is anyone else having this issue?
- JohnNadeauJan 02, 2016Apprentice
jflorance GyroD4 No problems here with 2.4G Connecting with various devices (multiple Android devices/versions; and multiple Windows devices/versions).
- GyroD4Jan 02, 2016Tutor
I have cycled the power on the router but haven't tried a hard reset (reset button). Is a hard reset required for the firmware to update properly? I can see the 2.4Ghz is there from my devices, they just won't complete the login process. I do not broadcast my SSID's, but have even tried broadcasting to no avail....
- LeeHJan 02, 2016Prodigy
Many people experience problems when they don't reset the router after doing a firmware update. Press in the reset button for 30 seconds to ensure a proper reset.
I reset both before and after a firmware flash because I had a problem once when I didn't reset before a firmware flash.
- tpartyJan 21, 2016Aspirant
I'm having the same issue here .. any fixes???
Terry
- rpoffenJan 21, 2016Virtuoso
Which issue? There are many issues with this version.
Probably the best fix is to revert back to an older version. 1.0.4.28 and 1.0.4.30 seem to be the most stable.
