fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
shamarin
Jan 02, 2016Virtuoso
For me too there is no problems with 2.4G devices connection. All my devices connects good on bouth 2.4 GHz and 5 GHz bands.
hugoless
Jan 02, 2016Tutor
I have the same problem with the 2.4Ghz wifi.
I have tried a lot of things but it is impossible to connect to that network.
Is there a way to configure it to make it work ???
- buddy_tJan 03, 2016Aspirant
All devices connect on mine by just disabling security, of course that is inacceptable!
- LeKeiserJan 04, 2016Luminary
So you confirm that with the SSID disabled, your devices cannot connect to the network? That you have to enable the broadcast for them to be on the network?
My android tablets and my Kindles can't connect IF the SSID isn't broadcasted. I haven't had the time to check with my laptop running Win10. I'll do that tonight. But since it was working before and I haven't changed their configurations, it has to be the R7000 somewhere...
- omoellerJan 04, 2016Guide
After playing around with 5.52 and 6.28 both of them did not work for me - which is kind of interesting as I do nothing specail with the router - no guest wlan, no port forwarding - just plain simple WLAN router. Anyway, 6.28 was super looooow on UI, downgraded to 5.53 and lost my 5Ghz - and yes, did multiple factory resets per menue and button and reconfigured manually,. I now went back to 4.28 as it simply seems to do what it is supposed to do. The only interesting thing I came across is that it keeps losing assigned names to WLAN clients when it comes to access management. Good luck all ...
