fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
LeeH
Jan 02, 2016Prodigy
Many people experience problems when they don't reset the router after doing a firmware update. Press in the reset button for 30 seconds to ensure a proper reset.
I reset both before and after a firmware flash because I had a problem once when I didn't reset before a firmware flash.
hugoless
Jan 02, 2016Tutor
A hard reset, I have not done this before. Is there a procedure to follow ?
Do a hard reset completely clear the settings and do I have to save my settings ?
Is it the same as a "complete factory reset" ?
Thanks
