fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
shamarin
Jan 02, 2016Virtuoso
Yes, you can use your config file from previous firmware after hardware reseting of router after an update. I made the same during beta testing of new FW and all settings was restored good.
LeKeiser
Jan 02, 2016Luminary
thought it was better, if not a must do, NOT to use the backups when it was a new firmware release, like here going from 1.0.5 to 1.0.6? Read something about it from TheEther.
- TheEtherJan 02, 2016Guru
Yes, restoring from a backup file can undo the effect of a factory reset. 1.0.5.48 introduced some big changes, so do not restore from a backup created from an earlier version.
Going from 1.0.5.48 to 1.0.6.28 may work because I doubt any new incompatibilities were introduced, but a factory reset is a sure way to start from a clean slate.
- jfloranceJan 03, 2016Star
I did a factory reset and manually configured my settings. I haven't tested every 2.4Ghz device in the house but seems to have worked. I don't remember which firmware version I updated from but I am sure it was 6-9 months old. I am going to assume that taking a long leap in firmware versions was the culprit.
Thanks for all the good suggestions. I don't think there is one cause for all the issues people are seeing. Remember, your actual mileage may vary.
- LeKeiserJan 03, 2016Luminary
Well I decided to go for this new firmware. Did a reset, then uploaded the firmware from my computer, then re-applied all my settings. So far, so good I think. I have activated the access control feature with all my devices (yeah yeah I know TheEther :D ) and I can still see my printer so ReadyShare Printer seems to be working also.
I'll see how stable the router is. WiFi seems to be correct, I haven't noticed any lag yet. I'll see later when I watch Luther on Netflix, better work or there'll be mayhem!! :)
Ah, I didn't reset the router AFTER the upgrade. Thought what's the point of doing another reset to go back to which firmware, since I have just uploaded the latest one?
