fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
jflorance
Jan 01, 2016Star
I updated to 1.0.6.28 yesterday and have lost access to my 2.4G network. I have both 5 and 2.4 running and a 2.4G guest network . The guest network seems to work fine. I've tested it with on Android device and 2 Windows laptops. I'll entertain any workarounds or solutions.
Probably doesn't matter but I turned off Arlo right after the update.
joprix
Jan 03, 2016Guide
After upgrading I too have suffered from the total loss of my 2.4Ghz network, which is a real pain. All I get when I try to connect is "cannot connect to this network", which tells me nothing.
Don't Netgear test this stuff before releasing it? So now all my wireless stuff will only work over 5Ghz. I'm hoping Netgear will release a fix for this stuff-up.
Any suggestions; baby steps please, I have no idea what I'm doing with this.
- LeKeiserJan 03, 2016Luminary
Oh one thing I did notice and forgot to mention is that if I hide the SSID of my WiFi, then my devices cannot connect at all. I have to enable it to make it work.
Bug then?
- jfloranceJan 03, 2016Star
I consider myself moderately technical when it comes to networking. I suggest reviewing and screen capturing your current configuration and then do the reset. If you keep the old SSID and passwords you should be in good shape. Took me 15 minutes to capture everything and 15 minutes to reconfigure. I have some port forwarding, otherwise it would have gone quicker.
I never looked to see if there was a network configuration export. It would be nice. The configuration backup file is binary so you can't read it.
Was it a reply to my post? If it's a yes, then there is something I don't understand: a reset would revert the router to which firmware? The factory one? Or the one I have just uploaded?
I did a reset, uploaded the latest firmware, and started anew to enter the mac addresses of my devices, the port forwarding rules, and so on.
Everything seem ot be working well except the WiFi if I hide the SSID. In that case, my device can't log on the network. Maybe I've missed a configuration option somewhere?
I think a reset leaves it at what ever firmware is currently loaded. When I reset, I was still at the latest with no configuration.
I noticed if I stop broadcasting my 2.4Ghz ssid, all devices disconnect and never reconnect, even if they had "automatically connect when available" on. Turn broadcast back on and everything is fine. There may be more going on here than I understand. I always broadcast so I'm not sure I can call it a bug.
