fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
joprix
Jan 03, 2016Guide
After upgrading I too have suffered from the total loss of my 2.4Ghz network, which is a real pain. All I get when I try to connect is "cannot connect to this network", which tells me nothing.
Don't Netgear test this stuff before releasing it? So now all my wireless stuff will only work over 5Ghz. I'm hoping Netgear will release a fix for this stuff-up.
Any suggestions; baby steps please, I have no idea what I'm doing with this.
LeKeiser
Jan 03, 2016Luminary
Oh one thing I did notice and forgot to mention is that if I hide the SSID of my WiFi, then my devices cannot connect at all. I have to enable it to make it work.
Bug then?
