fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
LeKeiser
Jan 03, 2016Luminary
Oh and then what do you mean by doing a reset ? With a paper clip at the back of the router, the 30-30-30 thing ? Because if that 's the way, what's à factory reset then ? I mean, isn't it supposed to revert to the original firmware ? Or is there a different reset ?
jflorance
Jan 03, 2016Star
I think I did a factory reset. I used the paper clip in the back for 30 seconds. I did this twice, first time didn't seem to work. It wiped my confuration but left me with the latest firmware. I'm not sure what the 30-30-30 is but my goal was to simple wipe my configuration, not downgrade FW. Does that make sense?
- TheEtherJan 03, 2016Guru
A factory reset only wipes configuration. It does NOT downgrade firmware.
