fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
LeKeiser
Jan 04, 2016Luminary
It does and that's what I thought UI was but I wanted to be sure. 6.28 is as fast as the other firmwares for me. At least, not that I could notice.
How was the throughput for you, compared to say 4.28.
omoeller
Jan 04, 2016Guide
Honestly i did not measure throughput in detail - neither WAN nor wireless - in the end it looked like 6.28 was stable on 2.4 but shaky on 5 Ghz as I had recent connection drops. This turned to be worse with 5.52 but runs perfect under 4.28 I am now back with.
And as said I always did full 30-sec resets before and after upgrade incl. manual re-config....
- JamesGLJan 04, 2016NETGEAR Employee Retired
Hi TheEther,
I have requested already to set this thread to sticky thread.
- joprixJan 04, 2016Guide
For those of us that have lost one or other 2.4Ghz or 5GHz bands, what do we do to get it back? Just wait for another update to fix the update? Re-apply the update, if that's possible? What?
- chascentJan 04, 2016Luminary
Take my advice :
perform factory reset
load R7000-V1.0.4.28_1.1.64 firmware
Perform factory rest
Done
This is the most stable trouble free firmware for the R7000 period. These additions of Arlo camera,
network steering etc are not working and causing other problems. I did speed tests with the
R7000-V1.0.4.28_1.1.64 vs the latest and there ia no difference. The 28 firmware is rock
solid. Just try it.
CC
Thanks chascent,
I think I have no choice anyway, now I can't even log in to the router admin page and for a short time I even lost my 5Ghz signal too. I have to say, this is pretty bad form by Netgear.
Not impressed.
- shamarinJan 04, 2016Virtuoso
Do a hardware reset of your device. Press a reset button on router and stay pressed for 30 seconds till LED's began to blink. After reseting install your router again. It should work normally.
- edgrsanchezJan 05, 2016Guide
It doesn't, even after a factory reset after upgrading to 1.0.6, the issues come back. I can't access the router's GUI.
- ankyduJan 05, 2016Guide
Try this. I have the same issue. The router page will be accessible from your wifi laptop or mobile phone. Access the router over wifi and change it to wireless AP mode from router mode. Once the router reboots it becomes accessible via lan also on your desktop. But please make sure you have another router with dhcp enabled and connected to your r7000. For me this was the only way to access the router after several hard resets. Even restoring the 1.0.4.28 firmware and resetting the router does not fix this. Please confirm if this worked for you.
Nope, can't connect to it via mobile either. - LeKeiserJan 05, 2016Luminary
hello,
Out of curiosity, why do you want to access your router with this IP? After a reset, should be 192.168.1.1, right?
My AT&T Uverse modem uses 192.168.1.1 as its IP and assigns 10.0.0.1 to the router via DHCP.
I just prefer using 10.0.0.X for my home network. Even after doing a factory reset on the R7000 it detects that my router is assigned 10.0.0.1 and sets itself up correctly.
Mmmmh... I see. Weird configuration though, I think.
I have configured my cable as a bridge, so the R7000 gets the public IP, and I assign its private IP myself.
At least I wouldn't let the modem attribute the private IP...
Have you tried to set it up yourself? No DHCP, fixed private IP?
- BersaglioJan 05, 2016Tutor
1. You should configure AT&T Uverse modem as a bridge. Or disconnect (temporarily) a cable between this modem and WAN port of R7000.
2. Do another factory reset of R7000.
3. Try to connect (from internal R7000 network of course) using a browser via 192.168.1.1 address or via routerlogin.net
Hope this helps.
- TheEtherJan 05, 2016Guru
Two very good guides for enabling bridge mode (acually a pseudo-bridge mode but it accomplishes the goal of moving the public IP address to your router) on Uverse gateways:
